i have a 1980 ford f150 302 v8 i have been working on it for a while just got it back in shape and runing today.
But when i went to drive it when i hit the breaks the break pedal will stick and i have to use my foot to make it release ,so i was woundering if anyone would know whats wrong and how i can fix it.
i was working on the motor not the brakes that what puzzs me
thanks for any help you can give
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
How long has your truck sat? I know my dad's 79 Bronco will sit for a few months and then his pedal will stick when he goes to use it. After a while it will stop doing it. I have lubricated the pedal linkage but it didn't help. I think it is the rod inside the master cylinder that sticks (but I could be wrong). I don't worry about it, it will go away. Just make sure you lift that pedal up or your brake lights will be on and you will have a dead battery.
