Anyone else have THIS much difference in axle width??
After a bit more digging, it appears I don't quite have the front clip on straight... oops... But, the fronts still will be sticking past the fenders... Oh well, it won't matter when I slap that D60 in there and put some 35's on... LOL
Thanks all
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
yep when we tried to put duals on a 89 seems ford amd a wider rearend to fit dauls but bolt in the same place as your if you trie to put daulls on this rearend I would bet the wheels would rub the spring my 2 cents
FORDS always look better when pulling a CHEVY
