1978 - 1996 Big Bronco
87-91computer302/e4oed
Old Jan 1, 2005 | 06:48 PM
kbbostwick's Avatar
kbbostwick
I am trying to find a compter to fit this combination 302 fuel injection out of a 87 4x2 matched with a e4oed transmission out of my 91 Bronco. I have the 351/e4oed computer and the 302/not sure what transmission except it is overdrive. I would be more than happy to trade what I have. Any help would be great. Local salvage yards haven't been much help.
Old Jan 1, 2005 | 08:44 PM
greystreak92's Avatar
greystreak92
The only other OD transmission used in the light duty trucks was the AOD to the best of my knowledge but beyond that I'm afraid any info I could give would be a guess at best.
Old Jan 1, 2005 | 11:43 PM
Stokes's Avatar
Stokes
to get a 302/E4OD combo, your gonna have to swap in a newer computer to run it, E4ODs wherent used untill 92-, id compare underhood wire diagrams and run a 92- newer computer and harness, then splice it into the dash connections (you know that big plug of wires goin from the engine bay to cab) or you might luck out and be able to plug and play, either way you have some reading to do. i have also herd that you can now buy aftermarket computer systems to run just the E4OD, so basicly you would keep the 302/AOD combo computer, then run a seperate computer for the tranny.
