1994 Trans Problem
Old Jan 1, 2005 | 06:33 PM
Big Al 0008's Avatar
Big Al 0008
1994 Trans Problem
I have recently purchased a 1994 Ford f150 4x4 w/an E4OD trans. The Trans would jump every time it tried to go into second gear. Last week i removed a keyless entry, remote start up system and pulled the courtsy lamp fuse so they did not overheat. When i replaced the fuse the trans ran perfectly. About 2 days later it started jumping again. I pulled the courtest lamp fuse(which also conltrols the spedometor) and replaced it. Once again the trans ran like new.
How could i fix the trans permenetly with out having to pull the fuse every two days. I do not have a code reader and if anyone could recomend a decent one at a decent price it would be much appreciated. If anyone could also shed some light on my trans problem that would be great.
Thanks
Old Jan 1, 2005 | 06:42 PM
trike1946's Avatar
trike1946
Welcome to FTE. You can usually go to a place like Auto Zone and get the codes read for free. I think that pre 96 the code readers are vehicle specific. They are pretty cheap though, $20 to $30 I think. Is the speedometer working right? Is the fuse you are pulling bad, or are you just taking it out and putting it back in?
Old Jan 1, 2005 | 06:58 PM
Big Al 0008
The spedometer is working fine. the fuse is fine. I just pull the fuse and replace it.
Thanks for the code reader info
JPdiesel
Electrical Systems/Wiring
Sep 15, 2011 11:06 PM
JPdiesel
Sep 15, 2011 10:11 AM
JPdiesel
Sep 14, 2011 07:01 AM
mdg100
Oct 22, 2009 04:03 PM
falconer
Aerostar
Dec 3, 2005 06:08 AM
