Bronco II Ford Bronco II
engine or tranny prob?
Old Jan 1, 2005 | 06:09 PM
87b2guy's Avatar
87b2guy
Alright, i bought this 87 B2 about 4 months ago and its been running rough since then. Now im fed up and am going to get it running the way a true B2 should.
The problem is: when accelerating it doesnt shift until very high rpm's (sometimes i wonder if it will at all), and once i get up to speed (around 40) and give it a little more gas to pass another car or get those pesky tailgaters off my back it down-shifts and doesnt accelerate at all (the rpm's stay at about 2300-3000). Another thing is once i get to about 50-55 if i give it even a little more gas it down-shifts and practically slows down. Is this because thats all the little 2.9 has got, or does it have something to do with the tranny?
Lemme know>
87b2guy
Old Jan 1, 2005 | 06:16 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
Sounds like the modulator on the passengers side of the tranny, or misadjusted cable.
Old Jan 2, 2005 | 02:39 AM
87b2guy's Avatar
87b2guy
That would be a computer related problem? Can it be adjusted or should it be replaced?
2.9L v6 auto
87b2guy
Old Jan 2, 2005 | 02:23 PM
87 XLT's Avatar
87 XLT
Like Ken sez, it could be a modulator problem, but could also be a vacuum problem.
If this was mine, i'd hookup my vacuum gauge & see what vacuum looks like at idle & more importantly the vac gauge will tell you if you have a clogged cat.
For less than a dealer would charge to fix this you can buy a vac gauge/code scanner/fuel pressure gauge.
Just follow the directions that come with these-& in your Haynes manual- to do some simple testing & let us know what you come up with.
Old Jan 2, 2005 | 03:33 PM
87b2guy's Avatar
87b2guy
Hey thanks guys, ill take a look at the modulator and get a vacume guage to do some testin and let you know what happens
87B2guy
87 B2 2.9L V6 auto 30x9.5
Old Jan 3, 2005 | 02:51 AM
ShawnZ's Avatar
ShawnZ
You could also have a clogged cat.
Old Jan 9, 2005 | 08:16 PM
WILL210's Avatar
WILL210
Will210
I HAVE A 87BII THAt was doing the same thing, I adjusted the down shift cable
