E350 Front Tank
Old Jan 1, 2005 | 05:35 PM
trike1946's Avatar
trike1946
E350 Front Tank
Hi. I have a 90 E350 diesel, with two tanks. I bought it last spring. Since then there has been no trouble filling either tank. Last week it became almost impossible to fill the front tank. I get about a gallon or so and the filler tube fills to the top. After a while it goes down, but as soon as I try again it fills the tube. Anybody have a similar problem? Thank you.
Old Jan 4, 2005 | 07:18 PM
trike1946's Avatar
trike1946
After checking I found out that the tank looks full. The fuel gauge is reading the rear tank for both. When the rear is empty, the front reads empty as well. It does switch for running, but the gauge does not change. Is there a sending unit that goes bad?
Old Jan 5, 2005 | 02:26 AM
ACESN8S's Avatar
ACESN8S
Yes, the sending unit can go bad.
I haven't looked at my tank switch, but I'm wondering if there may be a wire on there that controls the fuel guage that may have come loose.
Patrick
Old Jan 5, 2005 | 05:15 AM
trike1946's Avatar
trike1946
Am I right in thinking it is on top of the tank? And it must be lowered to fix it? And is there anything else I should check while I have it down?
