Door agar alarm
Old Jan 1, 2005 | 03:06 PM
Tom Porter's Avatar
Tom Porter
Door agar alarm
The door agar alarm stays on all the time that the key is in the ign. And ovecourst the dome light stays on as well. Is this just a bad door switch?
Old Jan 1, 2005 | 05:50 PM
trike1946's Avatar
trike1946
Welcome to FTE. How old is the truck? Door switches go bad sometimes. Try an auto parts for a replacement.
Old Jan 1, 2005 | 06:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I second Robert in ...Welcoming you to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 1, 2005 | 07:31 PM
Franklin2's Avatar
Franklin2
If we assume you have a later model, then that's when they moved the door switches to inside the latch mechanism. Several on here have fixed your problem by spraying wd40 up in the latch mechanism.
Old Jan 3, 2005 | 09:01 PM
bigcowboyal's Avatar
bigcowboyal
Door Adjar / dome lights on
Hey Guys,
I have a 2000 f-250 superduty crewcab diesel and for some reason lately I have had the door adjar light up on the dash and everytime I drop below 15-miles an hour the interlights come on.
The doors are closed, but can't figure out the problem, any suggestions?
Old Jan 3, 2005 | 11:03 PM
Franklin2's Avatar
Franklin2
Spray the latches with wd40.
