General Automotive Discussion
gassy oil
Old Jan 1, 2005 | 01:28 PM
sixshootingexp's Avatar
sixshootingexp
Smile gassy oil
I keep getting gass in my oil. is this caused by carb flooding. engine wont start, i had coil and control module tested, theyre good. thanks
Old Jan 1, 2005 | 03:40 PM
76supercab2's Avatar
76supercab2
I guess it could be the carb flooding but I would check the fuel pump first. Since you mention a carb, I assume you have the mechanical fuel pump mounted on the side of the block. If the diaphram ruptures, it can dump fuel directly into the block and oil pan.
Old Jan 1, 2005 | 05:01 PM
bdjupiter's Avatar
bdjupiter
I agree, it sounds like a bad fuel pump dumping raw fuel into the block.
Old Jan 1, 2005 | 06:08 PM
sixshootingexp
thanks, ill check it out
Old Jan 1, 2005 | 08:53 PM
sixshootingexp
it was the carb. Im shooting all six like never before. yeah!!!!
thanks
