Sponsored by: Real Truck
Heater Problems
Old Jan 1, 2005 | 11:38 AM
junior146's Avatar
junior146
Angry Heater Problems
I have a 2004 450 Super Duty that will only blow air thru the defroster. Is the problem in the switch, fuse box or something else I'm missing? Please help.
Old Jan 1, 2005 | 01:37 PM
99f350sd's Avatar
99f350sd
That is usually an indication of a vacuum problem...No vacuum!
Look for a hose off or hissing noise behind glove box or under hood near vacuum tank.
Welcome to FTE
Old Jan 1, 2005 | 01:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. As you can see, the members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 1, 2005 | 03:22 PM
captchas's Avatar
captchas
Guest
the newer heater systems are designed to go into deforst when they loose vac. listen and check for a leak, broken hose maybe even a mice chewing into a hose. good luck i'm sure you will hear it leaking
Old Jan 1, 2005 | 06:03 PM
99f350sd's Avatar
99f350sd
Oh goodness they did that back in the 70's
Old Jan 1, 2005 | 08:22 PM
captchas's Avatar
captchas
Guest
yes they did! but then i am a very old timer here . anything after 1970 is new style to me. older then that is old style. just call me a old wind ok?
