clutch problems help!
Old Jan 3, 2003 | 12:22 AM
bulldog77's Avatar
bulldog77
I have a 85 ford f150 with a 300 6 and when i take off i have a bad vibration. I have a 4 speed. through the rest of the gears it fine just when i take off. I put a new clutch in about a year and a half ago. Also i have a leak in my rear seal would that cause problems. How hard is it to fix that rear seal by the way, it is getting worse.
Any advice is appericated. THANKS.
Old Jan 3, 2003 | 01:32 AM
Robert Red Ford's Avatar
Robert Red Ford
Clutch chatter. Caused by iregular surface on flywheel, can be fixed by takin flywheel to a flywheel lathe. Or you might have oil on the clutch disc caused by the leaky rear main
Old Jan 3, 2003 | 12:16 PM
Franklin2's Avatar
Franklin2
You can also double check your motor mounts.
Old Jan 3, 2003 | 03:20 PM
ihregistry's Avatar
ihregistry
