explorer fuel system
Old Dec 31, 2004 | 10:13 PM
briaki's Avatar
briaki
I have a1991 explorer. The problem is ,the fuel pump continues to run after the ignition is turned off. It will run until Ipull the battery cable. Any ideas or feedback anyone? thanx ; briaki
Old Dec 31, 2004 | 10:34 PM
mrshorty's Avatar
mrshorty
A few possible solutions; the circuit isn't too complicated if you get a wiring diagram. I would suggest you get a diagram, and work through the circuit real quick. If I had to guess, it's most likely a stuck fuel pump relay.
