<HR style="COLOR: #666666" SIZE=1><!-- / icon and title --><!-- message -->the compression test I originally took was with gassy oil, and cold engine. The second test was after oil change and new carb.
first test showed 5 cylinders were at 110, and number 4 cylinder at 135psi.
second test showed 5 cylinders at 125, and number 4cylinder at 150-175psi.
this would be indicating?
this is on f-150 2 wheel drive 6cyl. 300ci. 97,000 miles.
not starting
<!-- / message -->
