windshield leaks
Old Dec 31, 2004 | 12:54 PM
gatorfan's Avatar
gatorfan
windshield leaks
I recently had my ’71 f100 windshield replaced by a pro. After the first good rain, I noticed a leak coming from inside the windshield pillar down to the bottom of my dash. I was able to isolate the leak to the top corners of the windshield seal. When I pull back the corner of the seal on the inside of the truck it is filled with water; not leaking inside, but still wet. I did metal repair and sealed the edges around the windshield opening before the glass was installed. Does this sound like a bad install, bad seal, or did I miss a step in my repairs? Should a sealant be used on the seal?
Old Jan 6, 2005 | 03:32 AM
volfan945's Avatar
volfan945
i would just take it back to the pro's and let them deal with, thats what you paid for. btw good luck next year and we will see you on the field
