95 ranger problems
Old Dec 31, 2004 | 11:47 AM
jed12's Avatar
jed12
95 ranger problems
OK, I have a 95 ranger supercab 4wd 4.0L V6 MT. I have had a check engine light on for a little while and it did not bother me too much since the engine was running fine. A couple of months back I started to hear a ping - and had been meaning to look into it.
Well, a couple of weeks ago the truck started to stall when it would go from high-low idle when cold. I cleaned the IAC which did not help. I decided to clean it one more time and ended up cracking the diaphram - so it is now replaced. I also checked/cleaned the MAF (it looked fine). I believe the idle is now fine - however I need to try it a few more days before signing off on it.
I still have a check engine light. I have ordered an OBD II scanner so I can stop guessing, however I did have a question on the DPFE. I read the test procedure on the technical notes link. Step 9 says the VREF should be .5 volts with KOEO and hoses connected. Is this correct? Mine measured 5 volts, and to be honest, that makes more sense since it appears to be the input and there should be not be a voltage drop before that point.
I am measuring it from VREF to ground. Should I measure from VREF to sig ret instead? The DPFE SIG measures a consistent 1.3 - 1.4 volts (KOEO or with engine running). I want to get a hand vacuum to check it under pressure.
edit: misread door ajar section
Old Dec 31, 2004 | 12:02 PM
pintopower8's Avatar
pintopower8
sounds to me like it needs the throttle body cleaned out good as far as the high to low stalling goes.
Old Dec 31, 2004 | 11:19 PM
el conquistador's Avatar
el conquistador
If you clean the TB, clean out the intake manifold also. it can get pretty nasty in there (carbon buildup).
