brake upgrade
Old Dec 30, 2004 | 11:40 PM
mattie333's Avatar
mattie333
brake upgrade
any suggestions for a reasonable [front] drum to disc-brake upgrade for a 1970 f100?
Old Dec 31, 2004 | 12:00 AM
Fomoko1's Avatar
Fomoko1
73 and up Ford F100/150 is a bolt in.
Old Dec 31, 2004 | 12:10 AM
mattie333's Avatar
mattie333
brake upgrade
so you're saying it's just a matter of simply slapping them on from a later 70s model? the kingpin is the same size and everything???
thanks for your help
Old Dec 31, 2004 | 01:12 AM
Fomoko1's Avatar
Fomoko1
I think that the 73 model year have the same king pin size but you can also swap the complete I-beams from the 74 and up. Some thing to think about if you don`t already have power steering is to swap that in at the same time from the same donor vehicle as most of the newer trucks had the p/s.
Old Jan 1, 2005 | 10:01 AM
fomoco's Avatar
fomoco
Check the Tech Article section... There is a good how-to article to help you with your upgrade
