ford radio
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about these trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Yes, no and maybe. How's that for an answer. There are companies making adapters to add a input that works through the the radios, but there expensive and radio dependent. The easiest and simpliest is use a fm modulator. It put a signal on the antenna at a given frequency. You tune radio to that frequency and presto, you have sound.
I have my XM wired that way. Only drawback is the mod. I am using requires that the source be turned off to use other stations. There are some out there that don't. I used one on my expy. to wire in a dvd.
