Offroad & 4x4
Hi steer a ball joint D60?
Old Dec 30, 2004 | 06:12 PM
nailhead's Avatar
nailhead
Possible?
My buddy is looking for tie-rod ideas for his 94 F350, without using a Z link tie rod.
Pics would be helpfull.
Truck has a shackle reversal with stock springs.
TIA.
Old Dec 30, 2004 | 10:57 PM
fishmanndotcom's Avatar
fishmanndotcom
yes it is possible and have seen it done but it's not all that common. i think Cleatus has a balljoint high steer arm but it was custom fabbed for him
-cutts-
Old Dec 31, 2004 | 06:42 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep, I gots one. Thanks for the props, fishy!
I guess a couple things I should add are:
1: It was more expensive than ORU-made one
2: It is WAY stronger than ORU-made one
3: It uses existing draglink (Just turn the lower end pointing downward instead of back) With shorter lifts, it may be necessary to shorten the draglink, but that's an EASY task.
Check out my gallery for pics of the high-steer block and specs so you can get one made!!
Cody
Old Dec 31, 2004 | 11:47 AM
nailhead's Avatar
nailhead
Thanks, this should get the ball rolling.
hhcobra
May 17, 2019 09:18 PM
rigsboo
Mar 6, 2017 12:05 AM
chetspencer
Mar 28, 2016 10:09 PM
arkredneck
Nov 9, 2011 01:34 PM
FX4 5.4
Jul 30, 2009 09:21 PM
