Steering Binding
Old Dec 30, 2004 | 06:12 PM
dlanc001's Avatar
dlanc001
Unhappy Steering Binding
I need help! I replaced the broken steering column in my '79 F150. The steering worked fine prior - the steering wheel was just too loose. Now the steering wheel binds and then lets go when I turn it. It appears that the bind is possibly in the gearbox or maybe the u-joint where the column ends. Anybody have an idea what's going on?
Old Dec 30, 2004 | 06:42 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my 78 F-250 did that, bind-slip-bind-slip, it was the knuckle on the steering shaft, i lubed it and it freed right up, every now and then it will do it again but i just oil it again, i dont know what the proper way is to lube it, i just poured oil over it, but my 4x4 was a bucket at the time and i wasnt worried about the mess...........
Old Dec 30, 2004 | 07:02 PM
007bronco's Avatar
007bronco
If you have a body lift the resulting angle on the rag joint can cause this. Had the same problem on my 79 Bronco and never did get it fixed. lubing the slip shaft may help.
Hope you have more luck than I did!
007BRONCO
Old Dec 30, 2004 | 09:44 PM
dlanc001's Avatar
dlanc001
I'll give the shaft lubing a shot, thanks for the suggestions.
Old Dec 31, 2004 | 08:12 PM
supercab4x4dually's Avatar
supercab4x4dually
This happen's to my 79 F350 4x4 (dually)plow truck every year when I go to plow again.From sitting all summer the u-joint in the steering shaft start's or dose seiz up cousing it to bind.I take my torch with very low low heat,and just warm up the u-joint,and then spray it hard with PB Blaster,and im off for the new seseon of plowing.
Old Jan 2, 2005 | 03:45 PM
twolls's Avatar
twolls
I had the same problem. Culprit was the steering u-joint. Got tired of messing with it and called Boregson for a replacement. I think the spelling is right, found them in a street rodders magazine, they do lots of nice steering stuff. Never had another problem.
ryanschillinger
16
Sep 10, 2014 08:30 PM
rderr
13
Aug 28, 2013 06:35 AM
smandzak
Dec 28, 2006 01:06 AM
rowdy123
Jul 11, 2005 10:26 AM
kurt russell
Oct 8, 1999 11:41 AM
