I have a truck that when you turn it off and remove the key, the instrument regains life after about ten seconds and all the guages turn back on. Ever heard of this problem??
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
When the gauges turn back on do they stay on or go off again? Do the warning lights come back on too? Where do the needles on the gauges point to? How long has it been doing this for?
I don't think there is anything that could cause that other than a faulty instrument cluster but to verify that you'd probably have to check the power wires at the back of the cluster to amke sure they didn't have power when they weren't supposed to.
