Sponsored by: Real Truck
4x4 not workin
Old Dec 30, 2004 | 09:59 AM
99goat's Avatar
99goat
4x4 not workin
i have a 2000 f-250 sd with psd 6 spd mnl trans. my truck only has the 4x4 switch on the dash. the hubs have no way to be manually locked. so i turn the switch to 4h put the truck in gear and the front wheels won't drive. i can hear the 4x4 kick in. so i had my wife get in and do the same thing while i looked under the truck to see whats turnin and whats not. everything was turning except for the front wheels. so i was thinkin that the hub might be bad. if they are what do i replace these hubs with? i called my local f dealer and was given a price of about 250.00ea. what do i do? i have also read that to install manuall hubs on my truck i'll need a kit of some kind for this swap. also are there any online manuals and diagrams that i might be able to use during my repair? this is my 1st time@fte so can someone please help me?
Old Dec 30, 2004 | 10:05 AM
RJB1's Avatar
RJB1
The conversion to manuals is pretty simple. The kit has everything that is needed generally. First verify that you don't have a vacuum leak, or a kink in a line. I believe that is what engages the front hubs.
Old Dec 30, 2004 | 10:15 AM
99goat's Avatar
99goat
thanks but i have read that i don't need a conversion kit and i have read that i do . how will i know? and where do i start the check for a vacuum leak?
Old Dec 30, 2004 | 10:18 AM
RJB1's Avatar
RJB1
Can't say if you do or don't need a conversion kit, that will be for the parts counter on my x ploder it was only a different nut and spacer. As for the vacuum line look down at the axle near the spindle to start
Old Dec 30, 2004 | 10:21 AM
99goat's Avatar
99goat
thanks again. goat
Paul T
1983 - 2012 Ranger & B-Series
Feb 14, 2025 06:31 AM
BarryOwings
Mar 27, 2014 04:19 PM
Abzack
Dec 1, 2009 01:36 PM
DonClifford
Sep 17, 2008 06:04 PM
BigV
Apr 15, 2003 04:49 PM
