New Motor
Old Dec 30, 2004 | 08:57 AM
oldhank's Avatar
oldhank
New Motor
My 72 Camper Special's 360/390 is tired. and I plan to get a new motor. My price range is up to $6000
I want big block and tons of power and torque but I don't want to change out my C6, etc. What do you guys reccomend, any takers?
O'Hank
Old Dec 30, 2004 | 12:13 PM
thesprocket26's Avatar
thesprocket26
I would spend about 3500 on the motor and 2500 on the C6. Your transmission has to handle the power the engine puts out. Your combo is the same my buddy runs in his 59. I have a 429 C6 and love it. You can make the C6 pretty stout. Upgrade all the components you can. They are an easy rebuild. Good luck.
Old Dec 30, 2004 | 12:42 PM
oldhank's Avatar
oldhank
new motor questions
now are you sure the c6 of my current FE motor will bolt up to a 429? or will there be necessary modifications?
i am looking for the right crate motor to quicky r&r the FE I currently have, I am not interested in a lot of retrofitting to install the new motor.
by the way, the C6 is very new. thanks for any guidance
Old Dec 30, 2004 | 12:48 PM
Six Niner's Avatar
Six Niner
the c-6 from your FE will not bolt up to a 429. sorry to burst your bubble. i believe a c-6 from a 351m-400 will bolt up to the 429 though. i would just builld a stout FE with aluminum heads, intake, etc. but thats just me. long live the FE!
Old Dec 30, 2004 | 12:59 PM
oldhank's Avatar
oldhank
Thumbs up new motor
can you advise anyone selling a kickin crate FE? I would like at least 400hp.
Old Dec 30, 2004 | 01:07 PM
Six Niner's Avatar
Six Niner
im not sure on the crate engine. if you have a good reputable machine shop (i.e. FE knowlegdeable) that can do the machine work, you can do the assembly. check out steve christs book avaliable here on this site. its a great FE manual. plus you can post any questions on the FE forum. those guys are fantabulous and a wealth of info. you might check the sponsors of this site for crate info. or do a google search. good luck.
Old Dec 30, 2004 | 01:12 PM
oldhank's Avatar
oldhank
new motor
hey 69er, would a 427 bolt up to my C6 bell housing without mod? this is an FE block, correct? i really don't have the time nor the resource to start building a new motor, I am looking for straight r&r. thanks for your continued help.
Old Dec 30, 2004 | 01:26 PM
Six Niner's Avatar
Six Niner
yes the 427 will bolt up, but thats not a good motor so youd better get rid of it... hey ill give you a $100 for it! you might check speed-o-motive, k u n tz and company, or keith craft for a crate engine. my buddies got a 9 second 63 1/2 galaxie that k u n tz did the motor in.
Old Dec 30, 2004 | 01:28 PM
thesprocket26
Sorry, I think we misunderstood each other. The Fe and the 385 series engines have different bell housings. I thought you were replacing a FE with another FE. I was using my 429/c6 as an example. Do you want to change engine series? Are you looking for any motor or just one that makes 400hp? What are your plans? What motor do you want in there?
Old Dec 30, 2004 | 02:53 PM
oldhank's Avatar
oldhank
new motor
sorry, i was having lunch.
two questions:
#1 why is a 427 no good?
#2 my pference is big block (FE included); i do not want to have to swap out everything else to r&r the motor i.e. tranny; i do not have time nor facility to build a motor; i want loads of HP and gobs to TQ i.e. 500/500 would be the goal.
what are your thoughts?
ol'hank
Old Dec 30, 2004 | 03:59 PM
thesprocket26
Those numbers will cost you 12K+. Try the website bigalstoybox.com
I think Six Niner was being sarcastic. It will bolt in and be quite a demon!
If you changed engine series, FE to 429/460, you would have to change motormounts, exhaust, transmissions, etc.
Six Niner's Avatar
Six Niner
sorry dude i was being sarcastic about the 427 not being any good. its a rare and desirable motor. youre blessed if youve got one. if you had a 390-say and put edelbrock heads and rpm intake with the right cam selection youre going to be over 400 ponies. more if youve got the 427-428 plus more low end torque. check those sites out and see if they offer any complete engine packages.
Old Dec 30, 2004 | 04:39 PM
oldhank's Avatar
oldhank
thanks for the clarification, sorry for being a little slow on the uptake about the 427 not being good. i thought i was missing something.
that said, i understand 427's to be rare motors in the junk yard, however you can buy a 427 long-block crate motor on the net, and these should bolt up to my FE/c6 bell housing correct? or am i missing something ??
otherwise, i might go for a 460 crate ($7000) and trash the current tranny for a bolt on c6 which marries the 460. dam the topedoes!
ol'hank
Old Dec 30, 2004 | 05:07 PM
russ71's Avatar
russ71
Some 427 cranks are NOT machined to accept a torque converter, I think most came with manual 4 speeds.
I know, had to have the crank machined.
Old Dec 30, 2004 | 05:22 PM
oldhank's Avatar
oldhank
460 it is.
all the best for 2005, i am outta here!
hank
