Bronco II Ford Bronco II
WARNING, read befor changing fuel filter
Old Dec 29, 2004 | 06:11 PM
DJ_FX's Avatar
DJ_FX
Exclamation WARNING, read befor changing fuel filter
I just changed the fuel filter on my 86 B2 4x4 and it is horribly designed. First of all, there is a tool for removing the cover but there isn’t enough space to get it on forcing you to use a strap wrench. Second, there is a metal plate that protects it against random objects that could damage it; it also prevents you from having an easy time removing the cover. Third, the brake line is WAY to close to the fuel filter cap.<O</O
If your brake line is really rusty, do NOT attempt to change the fuel filter, my strap wrench ruptured the brake line a little and now brake fluid is dripping out.
If your brake line(s) is/are in bad shape and you don't want to have to replace it/them, just take your Bronco to a garage and have them replace the fuel filter, then hope they damage the brake line and attempt to make them replace it (hey, if you play it right, you can get a free brake line installed). But make sure you get underneath and check before you leave because once you pull out, you can’t prove they broke it (pictures always help).
<O</O
Remember, always use jack stands (strong enough for the weight) and safety glasses when working under a vehicle.
bismic
Mar 7, 2026 11:32 AM
K8's Ford
13
Oct 19, 2010 05:39 PM
Damonkr
Mar 25, 2010 09:04 AM
dave_1001
May 24, 2008 10:11 PM
WIPSDFAn
Dec 23, 2004 10:09 PM
