Wiper Fluid Help
Old Dec 29, 2004 | 02:58 PM
qman's Avatar
qman
Wiper Fluid Help
I took the wiper fluid/coolant reservoir bottle off a couple weeks ago to clean out the coolant side. It was coated in rust and you couldn't see the coolant level. Anyway, to take it off I had to remove the wiper fluid hose from where it attaches to the bottom of the bottle. The hose is a hard plastic line but it connects to the bottle with rubber connector that has a 90 degree bend in it. This rubber connector has become hard and stretched and will no longer seal and stay connected to the wiper bottle. I even cleaned it real good and put silicone on the plastic part that juts out of the wiper bottle and let it dry for 2 days before putting fluid in there. I fill it with fluid and when I squirt wiper fluid onto the windshield the hose pops off and leaks all the fluid out. The local Ford dealer doesn't show this part. Anyone know what it is called, part number, or where I can fine one? I can't even find a hose clamp small enough to help.
Old Dec 29, 2004 | 05:58 PM
Beast12's Avatar
Beast12
Try a junkyard?
-Matt
Old Dec 29, 2004 | 06:35 PM
qman's Avatar
qman
I thought about that but I figured I'll end up with what I already have. The rubber has aged to the point it is hard and almost brittle.
Old Dec 29, 2004 | 06:39 PM
redneck4242002's Avatar
redneck4242002
junkyard or salvage yard is your best bet
Old Dec 29, 2004 | 06:46 PM
93flare5.0's Avatar
93flare5.0
you might also want to try mustang parts suppliers because many of times the mustang and ford truck parts are compatible...but you prolly already knew that
Old Dec 29, 2004 | 07:24 PM
stubnail's Avatar
stubnail
try a small zip tie around it ived used this maney times till i could find a new part vacume lines small engine gas lines boat motor you name it hope it works
Old Dec 29, 2004 | 08:32 PM
Red Ford Truck's Avatar
Red Ford Truck
Thumbs up Someone knows where to get that part, just....
Post a picture of the part so we can see what it looks like and maybe someone will have one or will be able to tell you where to get it.
kn
