1978 - 1996 Big Bronco
351 T/C replacement ???? Timming Question ??? quick help...
Old Dec 29, 2004 | 01:52 PM
merkstang's Avatar
merkstang
351 Totally stock
Replacing T/C with 2Deg index Sprocket (FRPP)
should we set it straight up or advance or retard it and by how much.
looking for more power if possible....
thanks
Old Dec 29, 2004 | 04:39 PM
stevef100s's Avatar
stevef100s
I would install it straight up, but it's up to you. If you advance it, your maximum torque will come in at a lower rpm. If you retard it, your max torque will come in at a higher rpm then stock. We're only talking 2 or three hundred rpm's lower or higher.
