Front Diff. on '99 4x4..
Old Dec 29, 2004 | 11:12 AM
RobertJohn's Avatar
RobertJohn
Question Front Diff. on '99 4x4..
I believe I've read somewhere that the fluid weight is different between the front and read diff on my '99 F-250 sd 4x4..
Did I dream that or am I correct ??
And if so why ? I'm just curious but it would seem to me they do the same thing !
Old Dec 29, 2004 | 06:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You are correct. The rear is 75w-140 synthetic and the front is 75w-90 dino. I assume it's because the front axle doesn't have to work nearly as hard...but knowing Ford, it's prolly so they could save a buck.
Old Dec 29, 2004 | 06:39 PM
bug juice's Avatar
bug juice
Hey Cookie88 thanks for the info on fog light mod!
I got to do rear alxe seals soon on mine, leaking. I think someone told me to add a bottle of ford friction modifier to it when I fill it. I jacked both rear tires off the ground and turned one, the other tire turned the same direction, question, if both tires turn same way is this limited slip? Also do you put any of this friction mod. in front diff?
Old Dec 29, 2004 | 07:02 PM
cookie88's Avatar
cookie88
FTE Emeritus
No problem...
The front end has an open diff., so it does not need friction modifier. I personally do not use it in the rear differential either, I prefer to have a functioning limited slip.
Old Dec 29, 2004 | 10:15 PM
RobertJohn's Avatar
RobertJohn
OK....to keep it simple can I put the same 75/140 syn. in the front as is in the rear ?? Either changing it or adding ...
