Aerostar Ford Aerostar
Help Transmission Slipping
Old Dec 29, 2004 | 09:44 AM
gcreed's Avatar
gcreed
I have a 91 AWD 4.0 with the trans slipping when it is
cold, but when it warms up it doesent slip at all.
I was told by a mechanic that it was the filter.
Anyone have the same problem.
Gary,
Old Dec 29, 2004 | 10:02 PM
lasher's Avatar
lasher
make sure that you just arent low on fluid. the fluid expands when it get warm.
if it is low it will slip and when it warms up it will stop. if thats not it the filter could be blocked up but i think you would have problem when it warmed up but it sure is easy enough to chech by dropping the pan.
Old Dec 29, 2004 | 10:13 PM
Muffinman's Avatar
Muffinman
Does it slip more in reverse when cold?
Old Dec 30, 2004 | 08:08 AM
gcreed's Avatar
gcreed
Re:Transmission Slipping & Also Oil Leak
When the engine is cold in the morning it slips, but when I drive it
a little no problem at all. checked the fluid and it's fine.
It doesen't matter reverse or drive.
When it does. it takes about one minuite to engage in ether
reverse or drive.
Also I have a pretty good oil leak about 1gt every 50 miles or so
and have put some Barrs oil additive in it and it slowed down some
but still leaks. Is there any of them that works to stop it.
I drove it into an oil change shop and we noticed that it was leaking
where the tranny bolts to the engine, I was told that some are easy
and some are not to replace
He said that some are a half seal and you don't need to pull the tranny.
and it takes about an hour, I have a 91 4.0 AWD
Gary,
Old Dec 31, 2004 | 06:00 PM
lasher's Avatar
lasher
ya do need to pull tranny out to change oil seal. i had to do it on mine. be care full i had to do it twice as the new seals i got were out of spec and they leaked. the third was a charm. its sound like your tranny could be sludged up and ya might need to change fluid a few times to get it cleaned up.
Old Jan 1, 2005 | 08:32 AM
gcreed's Avatar
gcreed
Re:Oil seal & Tranny
Thanks for the reply,
I think this van has not had some serious maintaince in some time.
Now I hear a clank when I let off the gas or when I engage drive
or reverse.
If it isn't one thing it's another, I have had ujoints do this in other vehicles.
But I have a 91 AWD 4.0 Do you guys think it is the ujoint or AWD.
Best Regards,
Gary Creed
gcreed@netscape.com
Old Jan 1, 2005 | 05:59 PM
lasher's Avatar
lasher
u joint will do that. you can check them pretty easy. jack van off the ground and wiggle the drive shafts. you should feel the looseness if their bad
Old Jan 2, 2005 | 04:17 AM
gcreed's Avatar
gcreed
I tried that with one wheel, and if didn't seem to loose.
Do I need to get the axle all the way off the ground.
Gary,
Old Jan 2, 2005 | 11:25 AM
lasher's Avatar
lasher
its better with both wheels off the ground because everthing is nice and loose then.
now you can put the van in nutral and move the drive shaft and feel for looseness.
