1978 - 1996 Big Bronco
turn signal not working
Old Dec 29, 2004 | 08:01 AM
blusoul2's Avatar
blusoul2
Question turn signal not working
Hello I have a 1987 bronco xlt that the turn signal just stopped working on the left side it will turn on but not blink also my head lights are acting crazy they come on in high beam but in regular beam only one comes on so I have to drive it on high beam for my lights to be on. <O</O
also does anyone know what they look for in VA inspections of Vehicles? I have to take my truck through by the end of Jan and need to know what I need to work on in order to pass.<O></O>
<O></O>
Any help would be helpful.<O></O>
<O></O>
Thank you,<O></O>
Natalie<O></O>
<O> </O>
Old Dec 29, 2004 | 09:06 AM
big6-87bronco's Avatar
big6-87bronco
Hello,
It is possible that you have a turn signal bulb burned out. Do both front and back light up when you cut the signal on?
The one headlight that does not come on when you are in low beam has the low beam filament burned out and it will need to be replaced. It is a good idea to replace both headlight bulbs at the same time.
As for VA inspections, in my opinion it seems to vary a little from shop to shop as to what they actually do inspect. The major things they check are the brakes, tire wear, lights, exhaust, tie rod & ball joint play. But even the little things like the horn, windshield wipers , etc. should also be checked before getting it inspected. if you want the actual list as to what is on the inspection slip let me know and I will get it out of
my truck and list them for you.
Old Dec 29, 2004 | 09:31 AM
GSX1300R's Avatar
GSX1300R
There is a regulater for your turn signals on the fuse black, it will look something like a 1" round metal piece. This may be your problem with you turn signals.
Patrick
Old Dec 29, 2004 | 09:46 AM
stepman's Avatar
stepman
I think you meant to say flasher. If that burns out, you would lose both sides. I also believe (like big6) that you have a couple of burnt bulbs.
Old Dec 29, 2004 | 10:47 AM
blusoul2's Avatar
blusoul2
If it will be no problem I would like the list
Thank you for your help and recommendations
I will try these things out.
Natalie
Old Dec 29, 2004 | 12:21 PM
big6-87bronco
Hello again Natalie,
Here is the list on the VA Inspection slip, beside each one there are little check boxes with the sections, OK - Adjust - Install - Remove. No real need to be alarmed at the length of the list because most of the items are just mainly a visual inspection.
I actually have the mechanic I go to now check everything on the list especially the ball joints and tie rods just to be safe.
Brakes
Headlights
Signal Lights
Other Lights
Steering
Suspension
Exhaust System
Fuel System
Tires
Hood Latch
Emission Control
Windshield
Windshield Wipers
Other Glass
Mirror
Doors
Seats
Seat Belt
Floor Pan
Defroster
Horn
I hope this helps.
Alan
