Crossover steering conversion
Old Dec 28, 2004 | 07:03 PM
63SW250's Avatar
63SW250
I'm looking to know what it takes to convert a 78 f250 with six inches of lift to the crossover steering, I'm trying to eliminate the spacer between the knuckle and the steering arm. How hard is it/expensive, what parts would I need. Thanks
Old Dec 28, 2004 | 08:40 PM
proeliator's Avatar
proeliator
If you do a search in the off-road forum you'll find all the info you need. You can also check out my gallery for reference.
Old Dec 29, 2004 | 12:06 AM
ivanribic's Avatar
ivanribic
I've got under $200 into mine total. That's the kinpin arm, drop pitman arm, 2 feet of DOM, threaded tube bungs, and tie rod ends. It's pretty simple to set up. You may not need the drop pitman arm but on my truck (and I imagine yours will be the same) the crossmember interferes with the movement of the stock pitman arm.
Old Dec 29, 2004 | 08:26 AM
63SW250's Avatar
63SW250
yeah I looked under the truck last night and the stock arm would interfer, but the new drop arm I got might be ok. I'll go look in the offroad area thanks guys
