Shift kit?
Old Dec 28, 2004 | 06:00 PM
outlawnbfd's Avatar
outlawnbfd
Shift kit?
Was looking at a B&M shift kit. . ..What exactly does this do, how difficult is it to install, and when is the effect it has when i get into the gas? I have ridden in a 7.3L powerstroke with one and it really threw you back in the seat. Its for a 351w auto in a shortbed f150 with 35" tires. Thnx
-Drew
Old Dec 28, 2004 | 06:26 PM
84-250's Avatar
84-250
the pan and valve body need to be removed and then you have to decide if you want towing mode or strip mode. then you take the provided drill bit and drill in a certain place depending on which mode you pick. put the seperator plate between the valve body halves w/o the stock gasket. a spring is included to change in the valve body.
place modified valve body into trans.
i chose the towing mode in my c6 and it very firm/slamming and fast from 1-2 and fast n firm from 2-3.
