*Pics* please help, cant find clutch
Old Dec 28, 2004 | 04:26 PM
Einzee's Avatar
Einzee
I have a major prob. I own a Ford V8 w/ T-18 trans. I can't get help from Autozone B/C the drivetrain is in a Jeep. Can someone please tell me what vehicles these tranny's came in? I will attempt to give as much info as possible: The side of the case says T18. The top cover says T98. The input shaft is 10 spline. The trans is coupled to a transfer case. The clutch disk is 11" Also I need to know the size of pilot bearing/bushing.
Old Dec 28, 2004 | 06:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
Old Dec 28, 2004 | 07:00 PM
fordman300's Avatar
fordman300
an 11 in clutch and pilot bearing from any truck with watever motor your running will fitjust fine as all gas trannys use a 1 1/16 10 spline input shaft.
is it a hydraulic or manual clutch
Old Dec 28, 2004 | 10:34 PM
Einzee's Avatar
Einzee
its a hydraulic. Im looking specifically any model of vehicle that had v8 and this type tranny. Im replacing the clutch disk and pressure plate and autozone looks at me like im from another planet.
Old Dec 29, 2004 | 08:53 AM
greenhighboy's Avatar
greenhighboy
Take your old parts to the store with you. If they still can't help,find another parts store. Buy the clutch to match the engine.
Old Dec 30, 2004 | 05:00 AM
754x4fordman's Avatar
754x4fordman
Thumbs up
unless its a 1975 ford that had a 300 six then a rebuilt 390 with a 360 flywheel... just ran into that over the weekend...after 3 trips to the parts store...
by the way autozone sucks! i quit dealing with the fools there a while ago and went to advanceauto. just my 2 cents...ha ha
Old Dec 30, 2004 | 01:43 PM
jwtaylor's Avatar
jwtaylor
Removed post, sorry
