Computer Chips & Tuners
I need '87 2.9l custom chip!
Old Dec 28, 2004 | 03:13 PM
jason.ward's Avatar
jason.ward
Big oops, I didn't do enough research before building my performance '87 2.9l with air speed density system. I've contacted all the major chip/module manufacturers, so far no one can help. Off the shelf cips are for stock configured systems so I need a custom. W/O great detail, the mods include; intake and exhaust mods, ignition, port/polish heads, port and match upper and lower intake manifolds, lighten/balance rotating assy., high lift roller rockers, 19 lb injectors, 180 thermostat,and cam. If specifics are necessary I can post it for you. Anyway it runs good with no mechanical/functional problems except air/fuel(rich at low RPM and lean in the upper RPM's) and poor idle. Is there anyone out there who can make me a chip or will I absolutely have to convert to MAF. any help would be greatly appreciated.
P.S.
If your thinking of building a 2.9l, it realy isn't worth it.
Old Dec 29, 2004 | 08:43 AM
FTE Ken's Avatar
FTE Ken
There aren't many people who are going to want to touch it because it has "too much of my time for too little money" written all over it. Call DiabloSport and see if they can put you in touch with a local Revolution Dealer who handles EEC-IV and has a dyno. Be prepared to shell out for dyno time in addition. Frankly, you could have put in a bigger engine under the hood for less hassle and better results. Sounds like one of those projects where you need to throw in the towel before it gets more expensive.
Old Dec 29, 2004 | 05:46 PM
jason.ward's Avatar
jason.ward
It's already too expensive to throw in the towell, the entire truck is restored like new. Diablo has been giving me the run around for 3 months. I'm not particularly automotive electronics savy, I was just hoping someone out there knows of fix. thanks
Old Dec 29, 2004 | 05:55 PM
FTE Ken's Avatar
FTE Ken
Ask Diablo about Revolution dealers. Diablo won't want to handle themselves, but one of their Revolution dealers may.
Old Dec 29, 2004 | 06:18 PM
18vtx00's Avatar
18vtx00
it is possible to change to mass air system. i have seen it done on a 5.0L.
not on a 2.9L
that is why i swapped in a HO 5.0L into my BRII.
alot of wiring and scematics are needed to do it properly.
i had to make a complete engine harness from the 2.9 and the 5.0 to form one and yes it was EFI. and passed MA emminssions and no ses on.
good luck. james duff may be able to alter you a chip to fit your needs but they are already $300 for the stock chip.
Old Dec 31, 2004 | 12:36 PM
jason.ward's Avatar
jason.ward
Does anyone know of a fix just to manage the air/fuel without using a chip or module.
Old Dec 31, 2004 | 12:59 PM
18vtx00's Avatar
18vtx00
not possible, it is all controlled by the PCM.
you may be able to fool it if you were able to determine the proper resistance that it would require to change the IAT or the ECT. but that would be a stretch.
good luck. this is why i swapped in a 302ci
