Universal joint removal problem
Old Dec 28, 2004 | 02:37 PM
zchief's Avatar
zchief
What type of socket is used to remove the bolts on a differential axle assembly mating flange? I'm trying to change a universal joint but the bolt heads are not familiar to me. I thought they were male torx bolt heads but the sockets I bought wouldn't fit. It's on a 92 F150, 302, 2WD, E4OD.
Old Dec 28, 2004 | 07:23 PM
LilDuke's Avatar
LilDuke
Funny thing, I went through the same thing on my bronco II. Turns out all you need is a 12 point socket or wrench. Good Luck, Dave
Old Dec 28, 2004 | 08:56 PM
fordman300's Avatar
fordman300
12mm 12 pt socket
