429 Help
Problem: Keeps acting like it jumps time, backfires and blows out the ecm.
I have replaced the distribuitor 3 times and the ecm 4 times.
Any suggestions on what is going on??????
Would greatly appreciate some info.
Thanks
on edit: when you put the engine in did you put a ground strap from the engine to the frame, or run the ground from the battery to the engine, and frame. A ground can cause all kinds of problems, and then look at your wiring harness like I said.
