Am I missing anything?
Old Dec 27, 2004 | 10:34 PM
stokdd's Avatar
stokdd
Going to start on the front brakes on my '70 F-100 tomorrow. Just want to make sure I bought everything I'll need.
I have:
- shoes
- hardware/spring kit
- self-adjuster kits
- cylinders
- inner and outter bearings (incl. bearing seals)
- 4 cans DOT-3 fluid
- very large can brake cleaner
I plan on having the drums machined at Napa, and I also need to buy some grease for the bearings. Any special kind I should get?
Thanks!
Evan
Old Dec 27, 2004 | 11:57 PM
Faithful Old Road Dog's Avatar
I would have had a large can of dot 3 and four cans of brakleen. I usually use the high temp grease. You might want to invest in a bearing packer. Makes it quick and cleaner when packing bearings. Use a bit of grease where the shoes meet on the backing plate. Check the hoses to make sure they're still good. You might want to get a pair of brake pliers, but I've done just fine without them. Grease up the threads on the self adjusters.
Old Dec 28, 2004 | 12:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use caliper grease for those spots where the brake shoes contact the backing plate. If those spots are worn or grooved grind them flat but watch the plate thickness. On old stuff I have had those spots welded up then ground flat again when I could not get new backing plates.
Use a small amount of caliper grease or anti-seize on the self adjuster threads also. You do not want any lube to drip off.
Old Dec 28, 2004 | 01:21 AM
Jimbare's Avatar
Jimbare
all alone in the world
dont forget to check the front brake hoses, make sure they dont have any wet spots or big cracks in them.
Old Dec 28, 2004 | 11:33 AM
Chris Nikirk's Avatar
Chris Nikirk
NAPA was by far the highest for this stuff, especially the wheel cylinders.
Old Dec 28, 2004 | 12:42 PM
qman's Avatar
qman
Sounds like you've got it all. I'd replace the hoses if the originals are on there.
Old Dec 30, 2004 | 02:41 AM
stokdd's Avatar
stokdd
Welp, got the brake replaced today. Does have original hoses in there, but I'll replace those when I do the rear brakes. Now if only I had the tires to back up the nice brakes
