* Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
front end noise
Welcome, Mike in Illinois.
You last visited: Today at 08:58 PM
Private Messages: 0 Unread, Total 0.
User CP FAQ Members List Timeslips Calendar Search New Posts Mark Forums Read Open Buddy List Log OutWe encourage you to show your support for the forum sponsors. They make FTE possible! Click Here for a list of sponsors.
View First Unread *
Thread Tools Search this Thread Rate Thread
* #1 * *
Today, 09:11 PM
Mike in Illinois
front end noise
I have a 2000 excurision 4 x 4 diesel, it just started to make a intermittent clicking noise coming from the drivers side front end.
replaced the caliper and pads noise was still there,
removed the auto 4 x 4 hub and test drove, noise still there
I had a 96 F150 which had screw on type hub caps. The screws would back off once in awhile creating a ticking or clicking sound. Did you put the backing pads on the new pads? They are thin and keep the pads fram chattering. Did you pull both hubs or just the one you thoght was making noise? Also check your front drive axle ujoints. Hope this helps
Sounds like a typical u-joint failure. Very common on front wheel drive vehicles, not so much with 4x's. Key to diagnose is noise only when a hard turn. Keep us posted.
