C6's were used behind many different engines, you have to make sure the bellhousing is the correct one.....did the motor have an automatic behind it before???
Yes, the 460 did come with a C6 optional in trucks for many years up to about '96. As long as the C6 has the big-block bellhousing bolt pattern (351M, 400, 429, 460), it should bolt up.
