Sponsored by: Kumho
dana 135
Old Dec 27, 2004 | 06:39 PM
fordtruck87's Avatar
fordtruck87
dana 135
i have a dana 135 disc brakes wondering if i can swap the disc brakes with my dana 60
Old Dec 27, 2004 | 10:11 PM
SoCalDesertRider's Avatar
SoCalDesertRider
What kind of truck? What end of the truck is the 60 in? What size wheels are you running?
Old Dec 28, 2004 | 06:51 PM
fordtruck87
rear end 16.5's i looked at it today i do beleive ill be able to do the swap itll rid me of about 150 lbs in rear of truck and give me better stopping distance need it with the amount of lift i have
Old Dec 29, 2004 | 12:03 AM
SoCalDesertRider
Check the clearance of the calipers with those 16.5" wheels. Assuming this 135 axle came from an F550, the F550's came with 19.5's partly to clear the larger brakes and partly to use higher rated commercial size tires. Also, the wheel bolt patterns are different. They're both 8 lug, but the F550's are 225mm (8.86") bolt circle. F250/350's are 170mm (6.7") bolt circle on the '99-up trucks and 6.5" bolt circle on the older trucks.
