Help! P-1212
Old Dec 27, 2004 | 05:34 PM
WA.Ranger's Avatar
WA.Ranger
Exclamation Help! P-1212
Hey guy's, heres the problem. I just finished installing my highpreasure crossover hose, started the truck, looked for any leaks, then it died. I figured no big deal, maybe lost it's prime. But then after several attempts to start it, nothing. Grabbed my SCMT and have code 1212 show up. clear it, try to start several more times and still nothing. What next?
Old Dec 27, 2004 | 05:40 PM
mech2161's Avatar
mech2161
Code is for ICP voltage not at expected level. Check all connectors and pins.
Old Dec 27, 2004 | 05:59 PM
WA.Ranger's Avatar
WA.Ranger
Checked them at the "switch" seem OK
Old Dec 27, 2004 | 06:04 PM
mech2161's Avatar
mech2161
Any leaks,HPOP level, fuel pump cycle with key, wait to start lamp, tach move when cranking?
Old Dec 27, 2004 | 06:06 PM
WA.Ranger's Avatar
WA.Ranger
No leaks, Don't know about checking the HPOP level, sounds like the fuel pump cycles, and the tach does move when cranking.
Old Dec 27, 2004 | 06:11 PM
mech2161's Avatar
mech2161
Center of engine, front, remove cover, remove plug in top. Should not be lower than one inch from top. Add as necessary.
Old Dec 27, 2004 | 06:13 PM
WA.Ranger's Avatar
WA.Ranger
I'll check that right now.
Old Dec 27, 2004 | 06:28 PM
WA.Ranger's Avatar
WA.Ranger
The level is about 3/4" down.
Old Dec 27, 2004 | 06:36 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The black cap is the fuel filter. Directly forward of that is a large aluminum reservoir. Remove the small plug on the top of the reservoir and look inside to see where the oil level is.
If you did not mess with the ICP sensor plug while installing the crossover line, then I'd bet you have air in the HPO rail and there is a bubble under the ICP. Try unplugging the ICP and see if it'll start.
Old Dec 27, 2004 | 06:37 PM
WA.Ranger's Avatar
WA.Ranger
Thanks cookie, if it starts, do I plug the sensor back in while it's running?
Old Dec 27, 2004 | 06:41 PM
WA.Ranger's Avatar
WA.Ranger
Unpluged it, still no go-go.
Old Dec 27, 2004 | 06:42 PM
cookie88's Avatar
cookie88
FTE Emeritus
No. Let it run for a bit to get the air cleared, then shut it off before you plug it in.
Old Dec 27, 2004 | 07:15 PM
WA.Ranger's Avatar
WA.Ranger
Still won't start, batteries are getting low, and I got to leave for work in 10 hours. Oil level in the HPOP is about right from what I read, plenty of fuel in the filter resevoir, tach moving so I guess the cps is working. All of this fun to add a mod.
Old Dec 27, 2004 | 11:08 PM
Kwikkordead's Avatar
Kwikkordead
If there are no oil leaks anywhere, I would revisit this train of thought VEEERRYY thoroughly.
Old Dec 28, 2004 | 07:06 AM
WA.Ranger's Avatar
WA.Ranger
Well I went out this morning, turned the key before hoping in the Ranger, and she fired up! sputtered like there were a couple of injectors not firing, then cleared up. Thanks for the help guy's. I just learned a lot of info on the powerstroke fuel injection which I previously didn't know. That's what it's all about anyhow, right?
