Aerostar Ford Aerostar
Rear differential fluid capacity
Old Dec 27, 2004 | 02:51 PM
johncfox's Avatar
johncfox
Does anyone know how much gear oil the 7.5 rear end holds? I had a bearing go south on me in the differential and now need to replace the pinion gear and bearings that hold it in place. Also had anyone ever heard of a bearing going out in this rear end? Its a new one to me.
Old Dec 27, 2004 | 04:52 PM
Muffinman's Avatar
Muffinman
1/2" from top fill plug. 3.5 pints
Old Dec 28, 2004 | 05:05 PM
johncfox's Avatar
johncfox
I got a 4.10 ls from the boneyard today. Plan on putting it in tomorrow. Well anyways, on a limited slip differential isnt there supposed to be non-friction modifier added? How much of that stuff goes in? My 3.0 shorty is pretty quick off the line already, hopefully the different ratio will give it a little boost.
Old Dec 28, 2004 | 05:12 PM
Muffinman's Avatar
Muffinman
4oz for the rear end
Old Dec 29, 2004 | 11:06 AM
johncfox's Avatar
johncfox
Got the gears changed out earlier this morning. Now the van is alot faster on takeoff (gotta love that). Well anyways i thought that the bearing was out but it turns out that the part of the ring gear assy that the bearing is pressed on and rides on was no longer there. Now what would cause that? It was turned into chips that were conveniently located in the oil. Apparently when that went it caused the ring gear to move over slightly and the pinion gear and ring gear assy met each other head on. About half of the teeth were wore off the ring gear and the pinion was messed up pretty badly too. Oh well, just wish i could figure out what caused it to go haywire in there. Hopefully it wont happen again, cause i hate the smell of gear oil and lsd modifier. It smells especially bad when it is covering your body, and it is hell to get off.
1L243
Apr 22, 2017 12:25 AM
F250F250F250
Nov 17, 2012 07:40 AM
bigbluetruck
Dec 21, 2010 04:27 PM
cheetah85
Nov 29, 2009 07:50 AM
fordtrailer
General Automotive Discussion
Jul 4, 2009 11:58 AM
