Temperature Gauge
Old Dec 27, 2004 | 01:41 PM
taneum's Avatar
taneum
Temperature Gauge
I own a 1979 F250 Ranger 4x4. The temperature gauge goes up to the "L" on normal after the engine warms up and the needle just sits there in that position until I shut it off. No overheating out of the radiator cap is occuring. It does this in the summer and winter. The radiator is full of new fluid. Why does this happen?
Taneum
Old Dec 27, 2004 | 01:51 PM
73Custom's Avatar
73Custom
Do all the guages read high, or only the temp?
The guage works on a resistance through the sending unit. You could have a bad sending unit. Faulty wiring/poor connections. Or bad ground from engine to battery. Get a thermometer (or have a mechanic shop test it for a couple bucks) and see if the engine is in fact hot, or just the guage is off.
Marty
Old Dec 27, 2004 | 01:52 PM
taneum's Avatar
taneum
My other gauges look to be reading the way they should be. The temperature gauge is the only one that just reads high all the time once the engine warms up.
Old Dec 27, 2004 | 01:56 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
when i first got my truck,it had a 360 in it, it did that to me because the valve in the heater hose wasnt opening, normally that shouldnt cause any problems..but on mine it did, and when i removed the valve and replaced it with a flush tee...i had no problems after that.........
Old Dec 27, 2004 | 05:47 PM
Mil1ion's Avatar
Mil1ion
The gauge needle getting to the L is normal for a 195* Thermostat.
Unless it goes over the normal range mark,don't worry about it.
You can watch for a very minute' movement in the needles as well
Old Dec 28, 2004 | 12:22 AM
taneum's Avatar
taneum
Thanks for all of the information. How do I know if it's a 195 degree thermostat? Is that a standard thrmostat?
Old Dec 28, 2004 | 12:41 AM
SwOkcOffRoader
thats what i run in my 460, the only way to tell is to remove it and look at it, some tstats will have the degrees stamped on em, some dont...
Old Dec 28, 2004 | 08:22 AM
77fordguy's Avatar
77fordguy
If you are going to remove it to look at it, it would be better to spend the 6 bucks and just replace it with a new one. My temp gauge was acting weird a few weeks ago and I just replaced the thermostat and everything is cool.
Old Dec 28, 2004 | 09:16 AM
taneum's Avatar
taneum
Hey thanks alot guys. It's nice to have these forums to ask these questions.
taneum
Mar 22, 2013 01:00 AM
taneum
Feb 10, 2013 12:32 PM
taneum
Feb 9, 2013 09:25 PM
taneum
Jan 7, 2013 12:46 PM
taneum
Dec 16, 2012 08:23 AM
