Sponsored by: Real Truck
steering wheel adj?
Old Dec 27, 2004 | 01:24 PM
Badford's Avatar
Badford
steering wheel adj?
what is the best way to adj the steering wheel after you install a new trac bar. mine is off just alittle....
thanks
Tony
Old Dec 27, 2004 | 03:27 PM
Yeti's Avatar
Yeti
Adjust the sleeve on the drag link, be careful a little is a lot, try a 1/4 turn at a time.
Adjust it, tighten it, drive it to see where it is.
Old Dec 28, 2004 | 09:58 PM
mcjones44us's Avatar
mcjones44us
I did this not long ago, mine was off after getting an alignment. If you first park the truck with the front wheels pointing straight forward as best you possibly can, then make sure your steering wheel is unlocked. Then, as you adjust the drag link sleeve the steering wheel will turn. Just adjust until your wheel is level & you're done. Helps to have an observer watching your wheel for you...
I found a thread or two on this site, search for "+drag +link"
Old Dec 29, 2004 | 02:19 AM
Badford's Avatar
Badford
What did you use to turn the sleeve? a pipe wrench..
Old Dec 29, 2004 | 09:19 PM
mcjones44us
I actually just used a big pair of channel-locks. My threads were pretty clean and the sleeve turned pretty easily. your mileage may vary...
