460 date codes
Old Dec 27, 2004 | 10:59 AM
toddn78's Avatar
toddn78
460 date codes
I am putting a 460 in my 78 f250 and when i pulled the motor out of the donor truck i started looking at the casting numbers. the block has a d1v date code and the heads have a d3v date code. Is it normal to have 2 years difference in the block and heads or is this not stock but somthing that has been put together.
Old Dec 27, 2004 | 02:38 PM
4x4dump's Avatar
4x4dump
Yes it is normal
Old Dec 30, 2004 | 01:25 AM
Superdave's Avatar
Superdave
I had the same codes on a motor that came from a 77 Lincoln. It had not been touched.
As mentioned, it is a common configuration.
adam83
41
Aug 20, 2015 12:01 PM
Samsn4
21
Aug 27, 2014 05:47 PM
CropDusterMan
Jun 19, 2014 08:06 AM
77ford guy
Oct 4, 2009 07:40 AM
