Starting Problems
Old Dec 27, 2004 | 03:14 AM
armyman05's Avatar
armyman05
Unhappy Starting Problems
I have a 2000 Ford Windstar with a 3.8 The other day i tried to start and got nothing but my lights. I replaced the battery and still had the same problem, now i replaced the starter and still i can't get any ignition i dont even get a click HELP PLEASE i am all out of ideas.
Old Dec 27, 2004 | 07:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the site!
Enjoy FTE
Old Dec 27, 2004 | 08:29 AM
trike1946's Avatar
trike1946
Was the check engine light on the last time it ran? Was this all of a sudden? No other symptoms before now? Have you checked the relays, and fuses?
Old Dec 27, 2004 | 11:48 AM
Franklin2's Avatar
Franklin2
If you have part of the electrical, but not all, I would suspect a blown fuse or fusible link. Since you have a later model, I would look for a underhood fuse box. It may have some large value maxi fuses in it. See if these all look good, You may want to pull them out anyway to check for corrosion on the fuse terminals, even though the fuse may be good.
Old Jan 2, 2005 | 01:49 PM
jessej's Avatar
jessej
check to be sure the wire is good going to the starter solenoid.it is mounted on top of the starter.
