I have problem with my hub lock on my Ranger 1999. The transfert is ok because I'am able to put it in low range. I put the vehicul on low range and I remove the hub lock. There are not lock. I lock it and I reinstall it. After that I move the vehicul and it is evident the 4wd work ok. I stop the vehicule and I put it in 2wd. I remove the hub lock and there are already lock. My automatic lock seem not working. I think it work with a vacumm but I don't know how it work because when I removed the lock I never seen piston or other thing to lock or unlock the hub lock.
1- Inside of the Hub Lock 2- Axle without the hub lock 3- 2 pipes back to the brake disc. If it work with vacumm it is probably on of these pipe. (My truck have ABS)
