Dusted turbo??
Old Dec 26, 2004 | 06:22 PM
wycowboy's Avatar
wycowboy
Dusted turbo??
How do I check to see if a turbo/ engine has been dammaged by a cracked air box?
Ive head that you can look at the blades on the turbo and see if they look sand blasted or over polished. but I'm not sure wher they are or how to get at them or even where that are.
do i need and special toot or just a wrench set? greaty apricaiate any hep!!
Old Dec 26, 2004 | 06:42 PM
t.j.g.'s Avatar
t.j.g.
just pull off the plastic tube running from air box to turbo inlet you then will see the turbo intake blads then you will be able to see if the ends of the blade are rounded off or serverly pitted
you will also notice dust on the inside of plastic intake tube if dust was getting to turbo
Old Dec 26, 2004 | 10:30 PM
wycowboy's Avatar
wycowboy
t.j.g.
is the inlet to the turbo the first rounded piece of metal housing down stream of the air box that looks like it should have a fan in it?? way at the back and center in the engine compartment? thanks J
Old Dec 28, 2004 | 04:49 PM
t.j.g.'s Avatar
t.j.g.
yes it is and yes thier should be a fan in it
Old Dec 28, 2004 | 06:22 PM
farmb0y's Avatar
farmb0y
Get yourself a 5/16 nut driver and you can pull apart your intake rather quickly, and a flashlight to look down in the turbo.
Old Dec 28, 2004 | 06:56 PM
wycowboy's Avatar
wycowboy
great! thanks Guys
