gpr
Old Dec 26, 2004 | 03:18 PM
t.j.g.'s Avatar
t.j.g.
gpr
need some advice
ju st got done checking my glowplugs and gpr
i got a voltage drop of 2v across gpr when relay is acuated
is this enought voltage drop to cuase a no start at -12f with out being pluged in (had dino 10w 40w in it )
well anyway just courios i plan on replacing it monday
by the way just changed over to synthetic ( 5w 40w ) how many miles can u go between changes
Old Dec 26, 2004 | 03:56 PM
Quadzilla's Avatar
Quadzilla
You're not supposed to get more than about 1.0V drop across the gpr, so yours is at least adding to your problem, if it isn't the whole problem. I don't run synthetic oil, so I'll leave that question for someone that does.
Old Dec 26, 2004 | 04:16 PM
CAT_man_963's Avatar
CAT_man_963
For the synthetic - I personally wouldn't run it any longer than regular oil, unless you get into the oil sample testing thing. I put synthetic 5w-40 in my truck for the winter, and I will change it at the 5000 mile mark just like normal. Just my $.02!
Old Dec 26, 2004 | 04:31 PM
t.j.g.'s Avatar
t.j.g.
thaks for the info 5000 it is then
