no heat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 26, 2004 | 02:57 PM
chevygoneford's Avatar
chevygoneford
Exclamation no heat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
welll heres the deal ive cleaned the heater core and it gets hot real hot and the core box gets hot both lines get hot and still get only luke warm heat also have checked the air change door and it is closed . is there a vacuum changer somewhere i had heat for about 10 minutes and then it went cold again its a 92 e 150 van has new thermostat checked before installed new water pump and hoses please help too cold here in indiana
Old Jan 3, 2005 | 11:48 PM
pfogle's Avatar
pfogle
I'd look around under the hood. My '92 with a 351 would roast you out..... It sounds like your not getting the air out of the box. The blen door may be broken, so only part of it's moving.
