predator installed WOW
Old Dec 26, 2004 | 09:16 AM
14u2nv's Avatar
14u2nv
installed the predator on my 05 6.0 wow what an bun-kicking it got i am on the 65 hp mode and was waiting to pull onto a busy road when i got a break in traffic i hit the go pedal and laid a posi burnout 60 ft up the road i couldnt beleive it
Old Dec 26, 2004 | 10:53 PM
Maxium4x4's Avatar
Maxium4x4
Give the trans some learning time. If you like the 65Hp, wait till you load the 100Hp.....
Old Dec 28, 2004 | 12:03 AM
jdadamsjr's Avatar
jdadamsjr
Welcome to the predator grin club !!!!
These beast do respond to a little tweaking, don't they !
wait until u do a powerbrake up to about 2K rpms in 4x4 !!!!!!!
Old Dec 28, 2004 | 02:59 AM
JamesHuntsville's Avatar
JamesHuntsville
I just purchased a 05 F-250 Lariat SD CC 4x4 5 speed auto with 6.0L PSD. I have been reading about these Predators. I know nothing about a diesel so will someone explain to me what is a Predator and what does it do? Is this something that I should purchase for my new truck? Thanks for any information.
James (Huntsville,TX.)
Old Dec 28, 2004 | 03:26 AM
Maxium4x4's Avatar
Maxium4x4
Flash tuners....plug into the diagnostic port and reprogram ECU
Predator and Super Chips Micro Tuner (SCMT) are Flash programmers
Fuel Boxes-Capture the signal sent from the ECU and modify the signal
Banks 6-Gun,Edge,Instigator are Fuel boxes
Installing a Flash Tuner like the Predator or SCMT allows for upgrades from the original programmer.....the fuel boxes are plug & play
Hope this helps...
Old Dec 28, 2004 | 03:39 AM
Maxium4x4's Avatar
Maxium4x4
JamesHuntsville
If you enjoy performance a tuner is a nice addition. The 6.0 diesel performs well at stock settings. The speed limiter can be removed by most systems and a variety of different HP levels can be set to run. When towing and using a higher HP setting the exhaust must be upgraded to eliminate the higher exhaust gas temperatures. Towing and 1200+degree temperatures will result in turbo damage.
I have the Predator with Magna-Flow exhaust.
