interior light not working
Old Dec 25, 2004 | 01:24 PM
c487w's Avatar
c487w
after wiring in a 7 spade flat plug on my 2000 f-150 with elect brakes i cant get the interior lights to work in my trailer is there a relay i need or how do i get them to work everything else seems to work ok
Old Dec 25, 2004 | 04:02 PM
Franklin2's Avatar
Franklin2
Did you hook to a red wire in the truck's harness? In the 1999 diagram they show a "battery junction box" This box has fuses in it. They show a red wire for "trailer tow battery feed" running out of this box to the trailer plug. It is fed by a 30 amp fuse in this fuse box.
Old Dec 25, 2004 | 05:19 PM
c487w's Avatar
c487w
is the orange aux wire supposed to run the interior lights.on a trailer i had in the past you had to have the running lights on to be able to turn on the int.lights.the trailer is brand new so the lights should work if i can locate which wire runs the int lights
Old Dec 26, 2004 | 09:11 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. As you can see the members in this forum are very knowledgeable about these trucks; they will eagerly help you…with your question.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE and Happy Holidays
Old Dec 26, 2004 | 04:09 PM
Franklin2's Avatar
Franklin2
I don't know about the trailer wiring. I would take a small battery charger and use it to experiment on the trailer plug. If anything goes wrong, it has a circuit breaker made into it.
