'94 Ranger Suspension
Danger_Ranger
FORD 4 EVER!
I think most lift companies make kits for 2wd rangers, 83-88 anyway, Rancho, superlift, skyjacker and a few others. Might give their tech lines a call and see if you can get just the front springs and other related steering correction pieces. Or maybe just some type of spring spacer to fit under the stock spring, I don't know about a 2" spacer, seems that may be a little much to raise the spring from the perch. The steering stabilizer will be the same deal, maybe you can convert one from a 4x4 ranger to work in a 2wd, or just look at brackets from other set-ups to see if you can use a different mount for use. Good Luck, Chuck P.
